| Message |
So my passenger window either has ED , or performance anxiety. When I press both windows to go up , the passenger side take a longgg time. (Maybe cuz I'm doing it with my left and I'm a righty?) Today , it stopped half way. It was basicslly a semi... got up a little but not all the way. If I only press the passenger button to go up, it goes a little faster but not as fast as the driver's side. I swear its my alternator but I've tested it at auto zone and everything comes out fine. Just a background commentary, my battrry light was on for a while, was told my alternator coukdnt handle all thr load, then one day the battery light started dimming a little... then flickering on and off. Then never came back on and now all tests show its fine. But just a feeling that that's the problem. Howver, the odd part is when my mchwnic chwnged the battery and put a new battery in. EVERLAST maybe ? The car seemed to run better. Cold engije sputter died. And when I turned on my hids the rpms didnt drop. But , now its doing it again so I swear its thr alt. But again, all tests are normal at auto zone. I dont have A/C so when I put on load not sure if that even matters. or if theres a better way go test ? So, yeah back to my window. Based on above information, do I need to just lube up something? Maybe talk dirty to it? Windex viagra? Or just get a new window puler upper motor thing ? Thank you and goodnight
